跳转到主内容
Fahrenheit FHT 125PRMR Power Cord Replacement
你所需要的
  1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Power Cord Replacement: 步骤 2 中的图像 1,1
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Power Cord Replacement: 步骤 3 中的图像 1,2 Fahrenheit FHT 125PRMR Power Cord Replacement: 步骤 3 中的图像 2,2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Power Cord Replacement: 步骤 4 中的图像 1,2 Fahrenheit FHT 125PRMR Power Cord Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
    • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
  5. Fahrenheit FHT 125PRMR Power Cord Replacement: 步骤 5 中的图像 1,1
    • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
结论
4等其他人完成本指南。
Joshua Potts
于09/29/16注册
265 声望
撰写一个指南
团队
IUPUI, Team 2-2, Harley Fall 2016 IUPUI, Team 2-2, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S2G2
4 名成员
创作了4篇指南
3条评论
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - 回复
Where do you buy the power cord?
Dominique - 回复
probably available at electronic store
john john - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 14
总计 2,461
