简介
How to change the firmware with Sony PC Companion if you forgot your Password, PIN, Pattern, Screen Lock.
PC Companion will install the latest firmware on your phone and will reset it to the Factory setting.
You can use this technique also if your device not boot properly.
!!! This will erase all your personal data!!!
If your device is connected to the internet and you have an installed Google account on it, look at this manual:
视频概述
Search and download Sony PC Companion.
Now choose "repair my phone / tablet". By this way you can fully erase your phone and remove any security password, PIN etc., or change firmware if your phone have OS problem and can't be powered on correctly.
It will not let me does this because I haven’t got the password for my phone so when I go onto the pc companion it says that because my phone is locked I can’t do it I just need to be able to unlock my Xperia M2 help!!
Your PC must recognize your phone like SOMC Flash Device.
If you have a problem with drivers (your PC can't recognize your phone), search in the internet for "S1Boot Fastboot" drivers or use the link below.
When PC Companion finished with update process, disconnect the phone and switch it on.
Now your phone is in factory condition, with erased custom data and without password protection.
Did you do it successfully?
After repair software does not success and may the device contains modified software that cannot be repaired error code Ue getphoneinforooteddevice UE-2003
BD use this software
113等其他人完成本指南。
26条评论
thanks so much. btw if it says you should unlock first, just press emergency calls and it accepts it
really???????
my xperia ( LT22i ) is not listed
handset is stuck in a boot up mode / optimising of application - screen and power on/off have no effect - keeps repeating this process and getting hotter?
since the new android marshmellow tried to download - ???
PC Companion does not acknowledge the connection to the handset - requests to wait until restart complete and/or PCC detects handset - neither happen as stuck in loop - cables are all ok
HELP
Xperia Z
I can't get the three options that come after clicking on the "Support Zone " option, I need help!!!!
thom4jesus - 回复
Sony Xperia Z C0682 is not in the model list. What should I do?
how long does it takes (hrs) on software repair?? any guys.. ^^', tnx alot
I can't download the PC Companion!!!!!!!!!!!!!!!!
I'm having issues with my battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 3hrs. Can I do a factory reset or could my battery die during the process?
I Also did a battery health test and it said the battery is good
Clive Donk - 回复
What to do if the program says you have to unlock the phone, but you dont remember the passcode...?
same man, what you do?
How to recover my sony xperia d2005 after installing software update disconnected? I can open my phone but only dead android can see.
I'm having issues with my battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 1hrs. Can I do a factory reset or could my battery die during the process?
I'm having issues with my Xperia z1 battery suddenly dropping to 0 while using the phone even when not using the phone it dies after about 1hrs. Can I do a factory reset or could my battery die during the process?
The current version of Xperia Companion (v. 1.5.3.0) had 2 errors on my PC (W7 64 SP1):
1) Setup with .DLL problem: I fixed the problem by installing an update for Windows - Windows KB 2533623 (Windows6.1-KB2533623-x64.msu) -, easily found on the Microsot website. After the update, the Companion was installed normally;
2) Several failures when trying to upgrade or repair my smartphone, such as "unexpected error", "login failure", "download failure", etc .: I corrected the problem by uninstalling the "Sony Mobile Update Engine", by Control panel. This software is installed automatically by the Xperia Companion setup. After uninstalling this software, Xperia Companion will no longer display any errors (and will install the Sony Mobile Update Engine again during the operation of your device, this time not causing the error!).
At least for me everything worked this way and, since I did not see this unusual solution on another site, I decided to post it, in case it would be useful to someone else.
Good luck!
please whats the file to format my xperia its too slow and keep reloading over and over again
dear sir/ madam,
on my system, the Sony pc companion is not installing please help me.
hi how are u sir my phone xperia vl is not open password and no reset how can i solve it plz tell me soultion
syed adnan - 回复
Amazing this is so help full thank you so much SP flash
??? if i have Malware on my phone can using this program infect my lap top
