跳转到主内容
Factory Reset, Fix Android Problems with Sony PC Companion
视频概述
  1. Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 1 中的图像 1,3 Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 1 中的图像 2,3 Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 1 中的图像 3,3
  2. Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 2 中的图像 1,2 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 2 中的图像 2,2
    • Install Sony PC Companion in your PC.
  3. Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 3 中的图像 1,3 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 3 中的图像 2,3 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 3 中的图像 3,3
    • Connect your laptop to power supply since the update of your phone will take some time.
    • Now choose "repair my phone / tablet". By this way you can fully erase your phone and remove any security password, PIN etc., or change firmware if your phone have OS problem and can't be powered on correctly.
    • This is your last warning about losing your personal data.
  4. Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 4 中的图像 1,2 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 4 中的图像 2,2
    • PC Companion will download some files to prepare your PC for software update.
    • Your phone / tablet must be at last 80% for the update to proceed safely!
  5. Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 5 中的图像 1,3 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 5 中的图像 2,3 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 5 中的图像 3,3
    • Select the model of your phone.
    • You should not confuse the model.
  6. Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 6 中的图像 1,3 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 6 中的图像 2,3 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 6 中的图像 3,3
    • The USB cable must be connected only to the PC.
    • Turn off the phone.
    • Press and hold the Volume Down button while plugging the cable into your phone.
    • Once connected, PC Companion will download necessary firmware and will upload it to your phone.
  7. Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 7 中的图像 1,3 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 7 中的图像 2,3 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 7 中的图像 3,3
    • Your PC must recognize your phone like SOMC Flash Device.
    • If you have a problem with drivers (your PC can't recognize your phone), search in the internet for "S1Boot Fastboot" drivers or use the link below.
    • '''Android WinUSB drivers'''
  8. Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 8 中的图像 1,3 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 8 中的图像 2,3 Factory Reset, Fix Android Problems  with Sony PC Companion: 步骤 8 中的图像 3,3
    • When PC Companion finished with update process, disconnect the phone and switch it on.
    • Now your phone is in factory condition, with erased custom data and without password protection.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
结论
113等其他人完成本指南。
ZFix
于12/09/13注册
191,278 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
26条评论
thanks so much. btw if it says you should unlock first, just press emergency calls and it accepts it
Godstime Osarobo - 回复
my xperia ( LT22i ) is not listed
abdul azeem - 回复
there is an error every time i try to use pc companion
error code: uegetphoneinfofailure
leo leo - 回复
there are an error
I can't download the upgrade on my phone
arnold - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 29
过去 30 天: 158
总计 231,384
