简介
If a stepper motor damper becomes worn or damaged it can cause a misalignment of the stepper motor and can cause the belt to slip. Slipped belts can cause layer shifts and other printing problems. Follow this guide to replace the damaged stepper damper.
你所需要的
Use 2.5mm hex key to remove 6 screws from base of printer
save screws for later
use 2mm hex key to remove belt cover
remove belt from stepper motor
use 2.5mm hex key to remove stepper motor bracket from the top side
use 2.5mm hex key to loosen set screws
slide geared pulley off of stepper motor shaft
use hex key to remove 2 screws holding the damper to the stepper motor
use Phillips #1 to install new damper
re-attach geared pulley
re-attach stepper motor mount/bracket to the damper
re-attach stepper motor bracket with screws from above
re-install pulley / tensioner to top of frame with thumb screw
re-tension belt
finally re-install the belt cover
To reassemble your device, follow these instructions in reverse order. If you have no screws left over, you win!
另外一个人完成了本指南。
