跳转到主内容
加入维修社区 - 创建账户
此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论
FLIR FX 电池更换
你所需要的
    1. FLIR FX 电池更换, 电池: 步骤 1 中的图像 1,3 FLIR FX 电池更换, 电池: 步骤 1 中的图像 2,3 FLIR FX 电池更换, 电池: 步骤 1 中的图像 3,3
      • 使用塑料开启工具撬开相机电池的后盖。
      添加评论
    2. FLIR FX 电池更换: 步骤 2 中的图像 1,3 FLIR FX 电池更换: 步骤 2 中的图像 2,3 FLIR FX 电池更换: 步骤 2 中的图像 3,3
      • 拧下设备四个角上的 1.2 mm Phillips 十字螺丝。
      询问修复机器人
      添加评论
    3. FLIR FX 电池更换: 步骤 3 中的图像 1,2 FLIR FX 电池更换: 步骤 3 中的图像 2,2
      • 接下来,取出电池和银色保护盖。
      • 用手或撬棒断开白色电池连接器。
      添加评论
结论
要重新组装设备,请按相反顺序执行这些说明。
取消:我没有完成这个指南。
4等其他人完成本指南。
Emily Bell
于03/20/17注册
392 声望
创作了3篇指南
团队
Texas Tech, Team S13-G2, Bennett Spring 2017 Texas Tech, Team S13-G2, Bennett Spring 2017 的会员
TTU-BENNETT-S17S13G2
3 名成员
创作了36篇指南
21指南评论
Do you know where we can find replacement batteries that fit?
albert stan - 回复 分享
Also looking for a replacement. Have a failing pack that has bulged the case. Currently talking with support. G713140AJ does not seem to be sold anywhere.
Fred Kolbrener - 回复 分享
So far it appears the battery was made specifically for FLIR. Their Tech support says they do not recognize the battery as a user replaceable item and recommends the unit be sent in for repair. Hopefully as time goes and more of these units fail the battery vendors on ebay and other places might begin to carry them. Until then this camera will be an expensive paper weight as it will not setup with its internal battery unplugged.
Interesting note, I took an xacto knife and carefully relieved the bulge in the battery. Some liquid came out and the battery went back to its normal size. I did plug it back in and believe it or not it actually worked. I dont trust it though as lithium Ion batteries have a tendency to catch on fire, I can just imagine what would happen to one that has been compromised.
Educated Consumer - 回复 分享
I spent a number of weeks trying to locate this battery including emailing battery vendors that import into the US. I finally got frustrated and contacted FLIR. I spent an additional week with emails going back and forth, FLIR will not sell you the battery for this camera. You can send it in for repair (which is really not cost effective) and they will send you a replacement refurb. One other interesting fact is that FLIR is closing out this camera, it has been replaced with the FLIR Secure HD. Somehow I would bet they aren’t using the same battery, lol
It is very disappointing that Flir is not selling replacement batteries. I have multiple FX cameras with bulging batteries and they will not go into direct connect mode anymore to allow me to change the WiFi password. The new models do not have batteries and they cost more than the previous model. They have HDR support and 16 GB SD cards, but are less versatile since they are strictly indoor security cameras. Flir is still selling the old models. The warranty is only a year long and the battery started swelling shortly afterwards. I use to recommend the FlirFX cameras, but not anymore. There are other brands that cost less and have the same features with the exception of the RapidRecap, but there is very limited access to that feature with the free plan.
Technology Trainer - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 25
过去 30 天: 51
总计 4,469
