跳转到主内容
FAO Schwarz Apex 1 Front Axle Replacement
你所需要的
  1. FAO Schwarz Apex 1 Front Axle Replacement, Wheel: 步骤 1 中的图像 1,3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: 步骤 1 中的图像 2,3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: 步骤 1 中的图像 3,3
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Front Axle Replacement: 步骤 2 中的图像 1,1
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
  3. FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: 步骤 3 中的图像 1,2 FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: 步骤 3 中的图像 2,2
    • Position device upside down so that the screws on the plastic axle pieces can be removed.
    • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
  4. FAO Schwarz Apex 1 Front Axle Replacement: 步骤 4 中的图像 1,1
    • Secure a firm grip on the spring and telescopic piston.
    • Pull telescopic piston holding the spring off the device (this may be difficult).
  5. FAO Schwarz Apex 1 Front Axle Replacement: 步骤 5 中的图像 1,1
    • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
  6. FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: 步骤 6 中的图像 1,3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: 步骤 6 中的图像 2,3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: 步骤 6 中的图像 3,3
    • Carefully turn the vehicle over so that the bottom side is facing upward.
    • Using a J1 Screwdriver bit, remove the two 10 mm screws that secure the wheel bearing.
    • Pull the plastic piece that secures the wheel bearing off of the axle.
  7. FAO Schwarz Apex 1 Front Axle Replacement: 步骤 7 中的图像 1,2 FAO Schwarz Apex 1 Front Axle Replacement: 步骤 7 中的图像 2,2
    • Position the axle entirely upright before lifting away from the vehicle.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 285
