跳转到主内容
Ezonics EZ-307 Main Board and USB Cable Replacement
你所需要的
  1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Get Tools: 步骤 1 中的图像 1,1
    • A Phillips Head Size Zero Screw Driver
  2. Ezonics EZ-307 Main Board and USB Cable  Replacement, Detach the Base: 步骤 2 中的图像 1,1
    • Using a Phillips-head screwdriver, remove each of the 3 screws from the underside of the camera head.
  3. Ezonics EZ-307 Main Board and USB Cable  Replacement, Set Aside the Base: 步骤 3 中的图像 1,1
    • Gently pull back the base and set it aside.
    • Be careful not to pull out the USB cable attachment when taking off the base
  4. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: 步骤 4 中的图像 1,3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: 步骤 4 中的图像 2,3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: 步骤 4 中的图像 3,3
    • Gently remove the white connector with the red, green, white & black cord with your fingers. This connector is the end of the USB cable.
  5. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: 步骤 5 中的图像 1,3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: 步骤 5 中的图像 2,3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: 步骤 5 中的图像 3,3
    • Press tab on inside of device to release silver ring.
    • Gently remove top (silver) ring of lens casing with your fingers.
  6. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Inner Lens Casing: 步骤 6 中的图像 1,2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Inner Lens Casing: 步骤 6 中的图像 2,2
    • Gently remove inner casing of the lens (silver with a black ring).
    • Be careful not to break the small notch at the top, which holds the inner casing in place.
  7. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove the Inner Ring: 步骤 7 中的图像 1,2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove the Inner Ring: 步骤 7 中的图像 2,2
    • Remove the small, black, ridged inner ring around the lens with your fingers.
  8. Ezonics EZ-307 Main Board and USB Cable  Replacement, Unscrew the Lens: 步骤 8 中的图像 1,2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Unscrew the Lens: 步骤 8 中的图像 2,2
    • Unscrew the lens counterclockwise with your fingers.
  9. Ezonics EZ-307 Main Board and USB Cable  Replacement, Carefully Remove Board From Outer Casing: 步骤 9 中的图像 1,2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Carefully Remove Board From Outer Casing: 步骤 9 中的图像 2,2
    • Turn the hollow outer casing so that you can see inside of it.
    • Gently pull out main board with fingers.
  10. Ezonics EZ-307 Main Board and USB Cable  Replacement, A New Board: 步骤 10 中的图像 1,2 Ezonics EZ-307 Main Board and USB Cable  Replacement, A New Board: 步骤 10 中的图像 2,2
    • Insert your new board into the outer casing. Be sure that it rests firmly between the sets of rails on either side.
  11. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassembly of Lens: 步骤 11 中的图像 1,2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassembly of Lens: 步骤 11 中的图像 2,2
    • Twist the lens piece in clockwise and then insert black ring around the lens.
  12. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: 步骤 12 中的图像 1,3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: 步骤 12 中的图像 2,3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: 步骤 12 中的图像 3,3
    • Line up notch on inner lens casing (silver with black ring) with notch on body of camera. Gently push it into place, being sure not to break the notch.
    • Insert the silver ring. You should hear it click into place.
  13. Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: 步骤 13 中的图像 1,3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: 步骤 13 中的图像 2,3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: 步骤 13 中的图像 3,3
    • Hold the camera in one hand with the hollow side facing up.
    • Hold the USB cable in your other hand with the four small holes facing up.
    • Plug the USB cable into the port.
  14. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Base of the Camera: 步骤 14 中的图像 1,1
    • Lay the USB cord in the notch at the base of the camera bottom.
    • Place the bottom back onto the camera top.
  15. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Base of the Camera: 步骤 15 中的图像 1,1
    • Line up the base of the camera with the screw holes.
    • Use a Phillips-head screwdriver to twist the three screws back into place.
结论
Lyndsi
于10/13/14注册
7 声望
撰写一个指南
团队
Ohio State, Team 1-5, Mccook Fall 2014 Ohio State, Team 1-5, Mccook Fall 2014 的会员
OSU-MCCOOK-F14S1G5
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 639
