跳转到主内容
加入维修社区 - 创建账户
Eyelash Extensions Replacement
你所需要的
  1. Eyelash Extensions Replacement, Eyelash Extensions: 步骤 1 中的图像 1,1
    • Wash hands thoroughly and make sure that the station and tools are cleaned and disinfected.
  2. Eyelash Extensions Replacement: 步骤 2 中的图像 1,1
    • Place the medical-grade tape under each eye, making sure that all the lower lashes are secured.
  3. Eyelash Extensions Replacement: 步骤 3 中的图像 1,1
    • Make sure that the client feels comfortable with the tape on with their eyes closed.
  4. Eyelash Extensions Replacement: 步骤 4 中的图像 1,1
    • Brush the eyelashes thoroughly using a mascara wand to remove the eyelashes that are ready to shed.
  5. Eyelash Extensions Replacement: 步骤 5 中的图像 1,2 Eyelash Extensions Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove all the grown-out lashes using the banana peel method.
    • Hold the natural lash in one clean tweezer and the eyelash extension in the other set of clean tweezers.
    • Gently pull the natural lash and the lash extension in opposite directions and peel the lashes apart like a banana.
  6. Eyelash Extensions Replacement: 步骤 6 中的图像 1,1
    • Brush the eyelashes again using a mascara wand after removing all the grown-out lashes.
  7. Eyelash Extensions Replacement: 步骤 7 中的图像 1,3 Eyelash Extensions Replacement: 步骤 7 中的图像 2,3 Eyelash Extensions Replacement: 步骤 7 中的图像 3,3
    • Put a drop or two of the eyelash primer on the micro swabs.
    • Dab the micro swabs on the eyelashes while making sure that it does not touch the eyelids as it can sting the client’s eyes.
  8. Eyelash Extensions Replacement: 步骤 8 中的图像 1,1
    • Let it air dry or use a fan for a faster dry time.
  9. Eyelash Extensions Replacement: 步骤 9 中的图像 1,1
    • Place a new lash extension using the eyelash extension adhesive of choice onto the natural eyelash, making sure that the eyelashes are isolated.
  10. Eyelash Extensions Replacement: 步骤 10 中的图像 1,2 Eyelash Extensions Replacement: 步骤 10 中的图像 2,2
    • Repeat Step 9 for both eyes until you are completely satisfied with your work.
  11. Eyelash Extensions Replacement: 步骤 11 中的图像 1,1
    • Inspect, separate, and brush the lashes to make sure that there are no upper lashes stuck on the lower lashes.
  12. Eyelash Extensions Replacement: 步骤 12 中的图像 1,1
    • Use a fan for 5-10 minutes to make sure that the adhesive is cured.
  13. Eyelash Extensions Replacement: 步骤 13 中的图像 1,1
    • Gently remove the tape from under each eye.
终点
April Pantaleon
于09/20/20注册
349 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 23
总计 605
