Position the camera with the bottom panel facing up
Use the 000 size Philips screw head
Carefully unscrew the panel
If you need, use the flathead driver to pry off the cover.
If not, simply pull off the panel
Once the battery is exposed, simply pull the battery out.
You may have to wiggle the battery to pull it out.
The battery is connected the camera by terminals for ease of removal
Be sure to keep the battery and camera clean during this step
push the battery back into the housing gently
Now, your camera is as good as new, have fun!
取消:我没有完成这个指南。
3等其他人完成本指南。
与1其他贡献者
于03/17/22注册
400 声望
创作了2篇指南
徽章: 9
+ 6更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 1,167
