跳转到主内容
ExoPC Slate Back Cover and Shield Replacement
你所需要的
  1. ExoPC Slate Back Cover and Shield Replacement, Back Cover and Shield: 步骤 1 中的图像 1,2 ExoPC Slate Back Cover and Shield Replacement, Back Cover and Shield: 步骤 1 中的图像 2,2
    • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
  2. ExoPC Slate Back Cover and Shield Replacement: 步骤 2 中的图像 1,2 ExoPC Slate Back Cover and Shield Replacement: 步骤 2 中的图像 2,2
    • Using the 00 Phillips screwdriver remove the two screws in the corners.
    • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
    • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
  3. ExoPC Slate Back Cover and Shield Replacement: 步骤 3 中的图像 1,3 ExoPC Slate Back Cover and Shield Replacement: 步骤 3 中的图像 2,3 ExoPC Slate Back Cover and Shield Replacement: 步骤 3 中的图像 3,3
    • Remove the tape covering the metal shield.
    • Remove the 12 screws using the Phillips #00 screwdriver.
    • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
结论
另外一个人完成了本指南。
Jonathon Cronin
于10/29/18注册
337 声望
创作了3篇指南
团队
UMass Dartmouth, Team S2-G1, Peak Fall 2018 UMass Dartmouth, Team S2-G1, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 349
