跳转到主内容
Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly
你所需要的
  1. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly, Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: 步骤 1 中的图像 1,1
    • Remove the two 10 mm screws from the plastic wire covering using a T5 Torx screwdriver.
    • Remove the covering.
  2. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: 步骤 2 中的图像 1,1
    • Remove the two 11 mm screws from the white plastic holding the outlet cord in place using a Phillips screwdriver.
  3. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: 步骤 3 中的图像 1,1
    • Remove the three 20 mm screws from the base of the iron using a Phillips screwdriver.
    • Two screws are beneath the rubber feet and one is in the wire compartment.
  4. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: 步骤 4 中的图像 1,1
    • Remove the base of the waffle maker to expose the heating conductor and wires.
结论
另外一个人完成了本指南。
附加文件
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 74
