简介
This tutorial will show you how to take apart the Euro Cuisine WM520 Heart Shaped Waffle Maker through a step by step process of removing screws. Be sure the iron is unplugged before taking apart because it heats up very quickly. Be sure to remove bottom rubber feet to take out two screws.
你所需要的
Remove the two 10 mm screws from the plastic wire covering using a T5 Torx screwdriver.
Remove the covering.
另外一个人完成了本指南。
