跳转到主内容
Eureka SuctionSeal 2.0 Pet Filters Replacement
  1. Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: 步骤 1 中的图像 1,2 Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: 步骤 1 中的图像 2,2
    • Place the device upright with the brush roller closest to you.
    • Pull up on the latch at the top of the dust cup.
    • Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
  2. Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: 步骤 2 中的图像 1,2 Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: 步骤 2 中的图像 2,2
    • Locate the gray exhaust filter cover at the top of the vacuum's base.
    • Grip the two tabs in the middle of the filter cover and rotate it counter-clockwise.
    • Lift the cover away from the vacuum.
  3. Eureka SuctionSeal 2.0 Pet Filters Replacement: 步骤 3 中的图像 1,1
    • Grab the tab on the exhaust filter.
    • Lift the filter straight up from the vacuum's base.
  4. Eureka SuctionSeal 2.0 Pet Filters Replacement: 步骤 4 中的图像 1,2 Eureka SuctionSeal 2.0 Pet Filters Replacement: 步骤 4 中的图像 2,2
    • Locate the lid at the top of the previously removed dust cup.
    • Lift the latch and lay the cover back.
  5. Eureka SuctionSeal 2.0 Pet Filters Replacement: 步骤 5 中的图像 1,2 Eureka SuctionSeal 2.0 Pet Filters Replacement: 步骤 5 中的图像 2,2
    • Pull up on the tag and remove the filter.
结论
Anna Snyder
于10/02/17注册
336 声望
创作了3篇指南
团队
Cal Poly, Team S4-G5, Livingston Fall 2017 Cal Poly, Team S4-G5, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S4G5
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 587
