简介
This guide will illustrate how to replace the Eureka SuctionSeal 2.0 Pet Brush Roll. Refer to this guide if your vacuum has low suction or you are having difficulty pushing the vacuum.
你所需要的
Place the device upright with the brush roller closest to you.
Pull up on the latch at the top of the dust cup.
Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
Locate the gray exhaust filter cover at the top of the vacuum's base.
Grip the two tabs in the middle of the filter cover and rotate counter-clockwise.
Lift the cover away from the vacuum.
Locate the belt latch assembly. It will be on your right when the brush roll is facing you.
Remove the two 20mm screws using a JIS 1 screwdriver.
Grab the brush roll on both ends.
Lift up on the right side of the brush roll.
Lift up on the left side of the brush roll, completely removing it from its frame.
Separate the brush roll from the belt and remove the brush roll from the vacuum.
另外一个人完成了本指南。
