跳转到主内容
Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement
你所需要的
  1. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Brush Roll: 步骤 1 中的图像 1,2 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Brush Roll: 步骤 1 中的图像 2,2
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 步骤 3 中的图像 1,2 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 步骤 3 中的图像 2,2
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 步骤 4 中的图像 1,1
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 步骤 5 中的图像 1,1
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: 步骤 6 中的图像 1,1
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
  7. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: 步骤 7 中的图像 1,3 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: 步骤 7 中的图像 2,3 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: 步骤 7 中的图像 3,3
    • Remove the belt from around the motor.
结论
8等其他人完成本指南。
Celina Burchett
于10/13/14注册
1,122 声望
创作了8篇指南
团队
Clemson, Team 2-2, Benson Fall 2014 Clemson, Team 2-2, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G2
4 名成员
创作了18篇指南
5条评论
It was Too hard So went to stretch the belt then it was on
missouri river production - 回复
To reassemble was not available for me so I kind of did it myself but I'm having trouble getting it back on straight
eternallight6 - 回复
i have read every sticker on this vbacuum read several maintenance steps …. i mean DA remove four screws …huh.
now can someone tell me whart size belt to get from the store
Sara Leinen
sparkplugkitten@msn.com
Sara Leinen - 回复
I got it used. I turned it on it worked. Then it just turned off and want come back on some please help me
nickietucker81 - 回复
Where's the trouble shooting
nickietucker81 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 37
总计 48,050
