跳转到主内容
Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement
你所需要的
  1. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Hose: 步骤 1 中的图像 1,2 Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Hose: 步骤 1 中的图像 2,2
    • On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
  2. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: 步骤 2 中的图像 1,2 Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: 步骤 2 中的图像 2,2
    • Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
  3. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Accessory Holder: 步骤 3 中的图像 1,1
    • Using a T15 Torx Security Screwdriver, remove the screw on each side of the indention in which the hose normally rests.
  4. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: 步骤 4 中的图像 1,1
    • Upon removal of the two screws, the accessory holder can be removed from the vacuum body.
结论
另外一个人完成了本指南。
Celina Burchett
于10/13/14注册
1,122 声望
创作了8篇指南
团队
Clemson, Team 2-2, Benson Fall 2014 Clemson, Team 2-2, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G2
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 750
