简介
If you determine that your vacuum brush roll will not turn and produces a burning smell, this guide will help you to replace the brush roll.
你所需要的
Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
6等其他人完成本指南。
1指南评论
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
Tami Jones - 回复
