跳转到主内容
Eureka AirSpeed Bagless Zuum Brush Roll Replacement
你所需要的
  1. Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: 步骤 1 中的图像 1,2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: 步骤 1 中的图像 2,2
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 步骤 3 中的图像 1,2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 步骤 3 中的图像 2,2
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 步骤 4 中的图像 1,1
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 步骤 5 中的图像 1,1
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: 步骤 6 中的图像 1,1
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
结论
6等其他人完成本指南。
Celina Burchett
于10/13/14注册
1,122 声望
创作了8篇指南
团队
Clemson, Team 2-2, Benson Fall 2014 Clemson, Team 2-2, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G2
4 名成员
创作了18篇指南
一条评论
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
Tami Jones - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 12,028
