跳转到主内容
Eureka 1660SP Roller Replacement
你所需要的
  1. Eureka 1660SP Roller Replacement, Roller: 步骤 1 中的图像 1,2 Eureka 1660SP Roller Replacement, Roller: 步骤 1 中的图像 2,2
    • Press the black separator switch and lightly pull the bottom half away from the top.
  2. Eureka 1660SP Roller Replacement: 步骤 2 中的图像 1,2 Eureka 1660SP Roller Replacement: 步骤 2 中的图像 2,2
    • Remove the vacuum head from the lower half of the body.
  3. Eureka 1660SP Roller Replacement: 步骤 3 中的图像 1,3 Eureka 1660SP Roller Replacement: 步骤 3 中的图像 2,3 Eureka 1660SP Roller Replacement: 步骤 3 中的图像 3,3
    • Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver.
    • Separate the top and bottom of the vacuum head. Set the top aside.
  4. Eureka 1660SP Roller Replacement: 步骤 4 中的图像 1,2 Eureka 1660SP Roller Replacement: 步骤 4 中的图像 2,2
    • Turn the vacuum head's bottom over so that the inside of the head is facing up.
    • Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
    • Turn the vacuum head's bottom over and pull at the roller and bar until they are completely out of the housing.
  5. Eureka 1660SP Roller Replacement: 步骤 5 中的图像 1,1
    • Press the new bar and roller into place.
    • Replace the screws.
终点
团队
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S1G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 461
