跳转到主内容
Eufy RoboVac 11S Filters Replacement
你所需要的
  1. Eufy RoboVac 11S Filters Replacement, Filters: 步骤 1 中的图像 1,2 Eufy RoboVac 11S Filters Replacement, Filters: 步骤 1 中的图像 2,2
    • Press the dust collector release button.
    • Pull the dust collector out.
  2. Eufy RoboVac 11S Filters Replacement: 步骤 2 中的图像 1,2 Eufy RoboVac 11S Filters Replacement: 步骤 2 中的图像 2,2
    • Push the blue button up and open the dust collector.
    • Empty the dust collector, and throw all the dust into the trash bin.
  3. Eufy RoboVac 11S Filters Replacement: 步骤 3 中的图像 1,3 Eufy RoboVac 11S Filters Replacement: 步骤 3 中的图像 2,3 Eufy RoboVac 11S Filters Replacement: 步骤 3 中的图像 3,3
    • Pull the hooks up to take out the pre-filter.
    • Pull the filter lightly because the hook by the filter is easy to break.
  4. Eufy RoboVac 11S Filters Replacement: 步骤 4 中的图像 1,3 Eufy RoboVac 11S Filters Replacement: 步骤 4 中的图像 2,3 Eufy RoboVac 11S Filters Replacement: 步骤 4 中的图像 3,3
    • Take out the high-performance filter to the side and use a cleaning brush to clean the filter.
    • Take out the foam filter to the side and dispose of it in the trash bin.
  5. Eufy RoboVac 11S Filters Replacement: 步骤 5 中的图像 1,1
    • Use the cleaning brush to sweep the dust from the pre-filter.
  6. Eufy RoboVac 11S Filters Replacement: 步骤 6 中的图像 1,2 Eufy RoboVac 11S Filters Replacement: 步骤 6 中的图像 2,2
    • Put the pre-filter back in the dust collector.
    • Use your finger to push the top button first.
    • Push the filter lightly because the hook by the filter is easy to break.
  7. Eufy RoboVac 11S Filters Replacement: 步骤 7 中的图像 1,2 Eufy RoboVac 11S Filters Replacement: 步骤 7 中的图像 2,2
    • Open the back of the dust collector.
    • Replace the white foam filter.
    • Put the black high-performance filter at the top of the foam filter.
    • Make sure to put the foam filter before the high-performance filter, otherwise the robot will have problems cleaning.
结论
2等其他人完成本指南。
felix
于05/13/20注册
181 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 86
总计 4,822
