跳转到主内容
Eufy RoboVac 11S Battery Replacement
你所需要的
  1. Eufy RoboVac 11S Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip Robocav Over on the soft side
    • Turn the power switch of the Eufy Robovac 11s to the off position
  2. Eufy RoboVac 11S Battery Replacement: 步骤 2 中的图像 1,1
    • Flip the vac over and use the Phillips to take out the two 5mm screws holding on the bottom cover. Set it aside.
  3. Eufy RoboVac 11S Battery Replacement: 步骤 3 中的图像 1,1
    • Lift off the bottom cover to expose the internal battery compartment and connector cable.
  4. Eufy RoboVac 11S Battery Replacement: 步骤 4 中的图像 1,1
    • Find the battery connector inside and carefully detach it to unplug the old battery.
  5. Eufy RoboVac 11S Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the old battery and properly dispose of it.
结论
To reassemble your device, follow these instructions in reverse order. If device still fails to operate complete the guide once again and make sure battery is full connected and charged.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 36
总计 358
