跳转到主内容
Eton FRX3 Motherboard Replacement
你所需要的
  1. Eton FRX3 Motherboard Replacement, Rechargeable Battery Pack: 步骤 1 中的图像 1,1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 Motherboard Replacement, Case Assembly: 步骤 3 中的图像 1,1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 Motherboard Replacement: 步骤 4 中的图像 1,1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 Motherboard Replacement: 步骤 6 中的图像 1,1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
  8. Eton FRX3 Motherboard Replacement, Tuning Dial: 步骤 8 中的图像 1,1
    • Unplug the socket connection from the motherboard as shown in the image.
  9. Eton FRX3 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the two 1 cm Phillips #0 screws that secure the tuning dial panel to the motherboard.
  10. Eton FRX3 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Gently lift the dial upwards to remove it.
  11. Eton FRX3 Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,1
    • Remove the six Phillips #0, 1 cm screws that secure the motherboard to the case.
  12. Eton FRX3 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Unplug all the component socket connections from the motherboard.
  13. Eton FRX3 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Desolder the two wires that connect the speaker to the motherboard.
  14. Eton FRX3 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Gently lift the motherboard upwards to remove it from the device.
结论
Md Siamul Islam
于02/10/16注册
423 声望
创作了4篇指南
团队
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016 的会员
USFT-NANCE-S16S1G6
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 444
