简介
The motherboard connects all the different components within the device. It's rare that this will malfunction, but if it does it may cause a wide range of problems from not turning on at all to erratic behavior. The LCD display is also soldered directly to the motherboard, if you would ever need to replace that.
你所需要的
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
Remove the six Phillips #0, 1 cm screws that secure the motherboard to the case.
