跳转到主内容
Eton FRX3 FM Radio Antenna Replacement
你所需要的
  1. Eton FRX3 FM Radio Antenna Replacement, Rechargeable Battery Pack: 步骤 1 中的图像 1,1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 FM Radio Antenna Replacement: 步骤 2 中的图像 1,1
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 FM Radio Antenna Replacement, Case Assembly: 步骤 3 中的图像 1,1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 FM Radio Antenna Replacement: 步骤 4 中的图像 1,1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 FM Radio Antenna Replacement: 步骤 5 中的图像 1,1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 FM Radio Antenna Replacement: 步骤 6 中的图像 1,1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 FM Radio Antenna Replacement: 步骤 7 中的图像 1,1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
  8. Eton FRX3 FM Radio Antenna Replacement, FM Radio Antenna: 步骤 8 中的图像 1,1
    • Remove the Philips #1 screw, securing the FM radio antenna to the case.
  9. Eton FRX3 FM Radio Antenna Replacement: 步骤 9 中的图像 1,1
    • From the back of the device, gently pull the antenna out of the device case.
结论
To reassemble your device, follow these instructions in the reverse order.
另外一个人完成了本指南。
Md Siamul Islam
于02/10/16注册
423 声望
创作了4篇指南
团队
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016 的会员
USFT-NANCE-S16S1G6
4 名成员
创作了13篇指南
3条评论
I bought 2 of these overpriced made in China crap and antenna broke off easily on both. Truly disappointed . Want to replace them with better heavy duty antenna. What brand and model and company do you recommend U buy the antennas from?
Olga Limkin - 回复
where can I get the antenna?
Claude Raasch - 回复
This helps when you leave it within reach of a 5 yr old who swears he did it when "he was little"
Joseph - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 17
总计 2,010
