跳转到主内容
Ethernet Port Replacement
你所需要的
  1. Ethernet Port Replacement, Linksys EA6900 Disassembly: 步骤 1 中的图像 1,3 Ethernet Port Replacement, Linksys EA6900 Disassembly: 步骤 1 中的图像 2,3 Ethernet Port Replacement, Linksys EA6900 Disassembly: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Ethernet Port Replacement: 步骤 2 中的图像 1,1
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Ethernet Port Replacement: 步骤 3 中的图像 1,1
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Ethernet Port Replacement: 步骤 4 中的图像 1,3 Ethernet Port Replacement: 步骤 4 中的图像 2,3 Ethernet Port Replacement: 步骤 4 中的图像 3,3
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Ethernet Port Replacement, Ethernet Ports: 步骤 5 中的图像 1,3 Ethernet Port Replacement, Ethernet Ports: 步骤 5 中的图像 2,3 Ethernet Port Replacement, Ethernet Ports: 步骤 5 中的图像 3,3
    • Locate the Ethernet ports
    • Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
    • Melt the 40 solder points using a soldering gun.
    • Wait between five and seven minutes for the ports to cool down.
  6. Ethernet Port Replacement: 步骤 6 中的图像 1,1
    • Hold the motherboard down and use the spudger to remove the Ethernet Ports.
结论
6等其他人完成本指南。
Denis
于09/15/16注册
584 声望
创作了3篇指南
团队
USF Tampa, Team 11-1, Blackwell Fall 2016 USF Tampa, Team 11-1, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G1
4 名成员
创作了12篇指南
一条评论
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
Enrique Jendrix - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 40
总计 7,212
