跳转到主内容
Ethernet Cable RJ45 Connector Replacement
你所需要的
  1. Ethernet Cable RJ45 Connector Replacement, Identify the parts of the tool: 步骤 1 中的图像 1,2 Ethernet Cable RJ45 Connector Replacement, Identify the parts of the tool: 步骤 1 中的图像 2,2
    • First let's identify which side of the tool performs which functions.
    • One side of the tool is used for stripping wires. You can tell because it has two blades, one on each side, as indicated in the first photo.
    • The other side is used for cutting wires. You can tell because one side is bladed while the other is flat, as seen in the second photo.
    • If you are using a slightly different tool, the use of it will still be very similar to how it is shown in this guide.
  2. Ethernet Cable RJ45 Connector Replacement, Cut the wire: 步骤 2 中的图像 1,2 Ethernet Cable RJ45 Connector Replacement, Cut the wire: 步骤 2 中的图像 2,2
    • Place the wire across the blade of the wire cutter.
    • Squeeze the handles of the tool together until the wire is cut.
  3. Ethernet Cable RJ45 Connector Replacement, Strip off the cover: 步骤 3 中的图像 1,3 Ethernet Cable RJ45 Connector Replacement, Strip off the cover: 步骤 3 中的图像 2,3 Ethernet Cable RJ45 Connector Replacement, Strip off the cover: 步骤 3 中的图像 3,3
    • Place about a quarter of an inch of the cable into the stripping end of the tool.
    • Squeeze the handles of the tools together until the tool clicks and then release.
    • Pull the stripped wire cover from the cable with your fingers.
    • If your wire cutter does not have a side specifically for stripping wires, you can simply use the wire cutting part but not squeeze the handles all the way down, so that it only cuts the outer casing of the cable.
    • When you have successfully completed this step, the cable should appear similar to the third photo of this step.
    • If you have shielded cable above Cat.5e you might want to follow this guide for stripping.
  4. Ethernet Cable RJ45 Connector Replacement, Organize the wires: 步骤 4 中的图像 1,2 Ethernet Cable RJ45 Connector Replacement, Organize the wires: 步骤 4 中的图像 2,2
    • Arrange these cables in the order shown in the diagram.
    • Use your fingers to squeeze the cables about to keep them in order.
    • This is how the cables will be inserted into the connector.
    • If you have S/FTP cables you likely won't have half white/coloured wires. These wires will instead be pure white and you will have to go by the colour of its partner in the twisted pair.
  5. Ethernet Cable RJ45 Connector Replacement, Trim the wires: 步骤 5 中的图像 1,2 Ethernet Cable RJ45 Connector Replacement, Trim the wires: 步骤 5 中的图像 2,2
    • Insert the cables into wire cutters.
    • Cut all the cables at the end so they are flush together.
    • Keep squeezing on the cables even after the cut to ensure they maintain the correct order.
  6. Ethernet Cable RJ45 Connector Replacement, Insert the new RJ45 connector: 步骤 6 中的图像 1,2 Ethernet Cable RJ45 Connector Replacement, Insert the new RJ45 connector: 步骤 6 中的图像 2,2
    • Hold the wires closely together in the order shown in the previous step and push them into the new RJ45 connector, with the clip end of the connector facing down, and the orange/white wire to the left.
    • Push the wires to the end of the connector ensuring that all wires enter their respective chambers in the connector.
    • If you inspect the top of the connector you should be able to see the tips of the wires pushed against the end of the connector, as shown in the second photo in this step.
  7. Ethernet Cable RJ45 Connector Replacement, Crimp the connector: 步骤 7 中的图像 1,1
    • Place the RJ45 into the crimper at the end of the tool. Push it in all the way, it will fit exactly in the tool—you can not push it in too far.
    • Squeeze the handles of the tool together until it clicks and releases.
    May someone please help confirm if this process works with CAT8 ? What will the differences be with a CAT8 cable? Thank you!
    carlosagonzalez2 - 回复
    Hey there, yes, cat8 still uses rj45 and the same wiring codes, so this guide still applies.
    Wesley Bigalke -
    I dont have the tool in the end can i do it by pressing by my hand or anything else ?
    Mohammed Lateef - 回复
结论
You have now replaced the RJ45 connector, you may test the fix by using using a cable tester. If it does not work, you can always follow the steps in this guide to try again.
29等其他人完成本指南。
Wesley Bigalke
于03/30/16注册
849 声望
撰写一个指南
团队
Michigan Tech, Team 1-2, Lauer Spring 2016 Michigan Tech, Team 1-2, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G2
1 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 51
过去 7 天: 331
过去 30 天: 1,688
总计 76,422
