跳转到主内容
简介
As more devices around us become dependent on an internet connection, we need more reliability and/or speed which can be met with a direct internet connection. Overtime, an Ethernet cable can become broken inside the sleeve and stop working from prolonged use. The value of enabling the everyday person to repair these vital cables would lessen the overall downtime they might face and help retain the majority of the cable by only replacing the broken portion. This would reduce overall waste being sent to landfills.
  1. Ethernet Cable Connector Replacement, Connector: 步骤 1 中的图像 1,2 Ethernet Cable Connector Replacement, Connector: 步骤 1 中的图像 2,2
    • Use the voltage tester to determine where the break in your cable is.
  2. Ethernet Cable Connector Replacement: 步骤 2 中的图像 1,1
    • Use a pair of wire cutters to cut the connector head off the cable, cutting one inch away from the breaking point.
  3. Ethernet Cable Connector Replacement: 步骤 3 中的图像 1,2 Ethernet Cable Connector Replacement: 步骤 3 中的图像 2,2
    • Insert the cable into the upper portion of the crimper to strip the outer sleeve of the cable.
    • Squeeze the handles and rotate the cable to ensure that the sleeve is cut all around.
    • Remove the crimper and then pull back the sleeving.
    • This will expose eight multicoloured wires.
  4. Ethernet Cable Connector Replacement: 步骤 4 中的图像 1,1
    • Pull the four pairs of cables in different directions at the base to make sure they aren't tangled.
  5. Ethernet Cable Connector Replacement: 步骤 5 中的图像 1,1
    • Untwist the paired cables and ensure that they are not tangled at the base.
    • Straighten the cables as best as you can and fold them back so all eight are all visible.
  6. Ethernet Cable Connector Replacement: 步骤 6 中的图像 1,1
    • Arrange these cables in the order shown in the diagram.
    • This is how the cables will be inserted into the connector.
  7. Ethernet Cable Connector Replacement: 步骤 7 中的图像 1,1
    • Use your fingers to squeeze the cables about an inch from the top to keep them in order.
  8. Ethernet Cable Connector Replacement: 步骤 8 中的图像 1,2 Ethernet Cable Connector Replacement: 步骤 8 中的图像 2,2
    • Insert the cables into wire cutters.
    • Cut all the cables at the end so they are flush together.
    • Keep squeezing on the cables even after the cut to ensure they maintain the correct order.
  9. Ethernet Cable Connector Replacement: 步骤 9 中的图像 1,1
    • While squeezing the newly cut cables, push the cables into the connector. The small grooves inside the piece should guide the cables into the back of the connector in the same order.
    • Push the cables inside to ensure that they are all the way to the back of the connector. You may need to apply additional force at this step to ensure they are at the end of the connector.
  10. Ethernet Cable Connector Replacement: 步骤 10 中的图像 1,1
    • Push the cables inside all the way with force until it does not move any deeper.
  11. Ethernet Cable Connector Replacement: 步骤 11 中的图像 1,3 Ethernet Cable Connector Replacement: 步骤 11 中的图像 2,3 Ethernet Cable Connector Replacement: 步骤 11 中的图像 3,3
    • Insert the connector with the cable attached into the crimper.
    • Push the cable into the back of the crimper until it cannot go any further.
    • Squeeze the handles of the crimper until you hear a small crunch.
    • This sound means that the teeth of the connector have gone into the cables and a connection is made.
  12. Ethernet Cable Connector Replacement: 步骤 12 中的图像 1,2 Ethernet Cable Connector Replacement: 步骤 12 中的图像 2,2
    • Look at the base of the connector and ensure you see eight cables with the sleeving around it.
    • You should be able to see all cables which means your connection is complete on that side.
    • Repeat steps 1-12 for the connector on the other side of the cable if needed.
  13. Ethernet Cable Connector Replacement: 步骤 13 中的图像 1,1
    • Insert the cable into the main tester unit.
  14. Ethernet Cable Connector Replacement: 步骤 14 中的图像 1,1
    • Insert the other end into the secondary tester unit.
  15. Ethernet Cable Connector Replacement: 步骤 15 中的图像 1,1
    • On the main tester unit, flip the switch to the ON position.
  16. Ethernet Cable Connector Replacement: 步骤 16 中的图像 1,3 Ethernet Cable Connector Replacement: 步骤 16 中的图像 2,3 Ethernet Cable Connector Replacement: 步骤 16 中的图像 3,3
    • The tester will cycle through all connections 1-8.
    • Ensure that the primary and secondary units are in sync, both showing the LED for the same number at the same time.
    • Verify all connections as one mismatched connection will render the cable non-functional.
结论
The same steps can be used to create an entirely new cable from Cat5/6 cable.
2等其他人完成本指南。
Karan
于2022年01月14日注册
274 声望分
撰写一个指南
团队
一条评论
Karan, Thank you so much for sharing this step-by-step guide on Ethernet cables. We at our Dublin SEO agency face a lot of internet issues due to turned ethernet cables, and we waste a lot of time aligning their color codes from both ends. Your guide will help us save a lot of time next time we find a broken Ethernet cable.
Adam James - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 13
过去的30天: 61
总计 185
