跳转到主内容
Etekcity Lasergrip 1080 Screen Replacement
你所需要的
  1. Etekcity Lasergrip 1080 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Screen Replacement: 步骤 2 中的图像 1,1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Screen Replacement: 步骤 3 中的图像 1,2 Etekcity Lasergrip 1080 Screen Replacement: 步骤 3 中的图像 2,2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Screen Replacement, Buttons: 步骤 4 中的图像 1,2 Etekcity Lasergrip 1080 Screen Replacement, Buttons: 步骤 4 中的图像 2,2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Screen Replacement: 步骤 5 中的图像 1,2 Etekcity Lasergrip 1080 Screen Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Screen Replacement: 步骤 7 中的图像 1,2 Etekcity Lasergrip 1080 Screen Replacement: 步骤 7 中的图像 2,2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Screen Replacement: 步骤 8 中的图像 1,1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Screen Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 步骤 9 中的图像 1,2 Etekcity Lasergrip 1080 Screen Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 步骤 9 中的图像 2,2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Screen Replacement, Screen: 步骤 10 中的图像 1,1
    • Carefully pull the motherboard out of its slot in the body of the device.
  11. Etekcity Lasergrip 1080 Screen Replacement: 步骤 11 中的图像 1,2 Etekcity Lasergrip 1080 Screen Replacement: 步骤 11 中的图像 2,2
    • Unscrew the two 3.4 mm screws on the motherboard.
  12. Etekcity Lasergrip 1080 Screen Replacement: 步骤 12 中的图像 1,1
    • Take off the cover and separate the parts.
    • All of these parts are fragile and mishandling them may cause damage.
结论
Carlos Pineda
于08/27/15注册
195 声望
撰写一个指南
团队
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S5G1
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 952
