跳转到主内容
Etekcity Lasergrip 1080 Button Replacement
你所需要的
  1. Etekcity Lasergrip 1080 Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Button Replacement: 步骤 2 中的图像 1,1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Button Replacement: 步骤 3 中的图像 1,2 Etekcity Lasergrip 1080 Button Replacement: 步骤 3 中的图像 2,2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Button Replacement, Buttons: 步骤 4 中的图像 1,2 Etekcity Lasergrip 1080 Button Replacement, Buttons: 步骤 4 中的图像 2,2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Button Replacement: 步骤 5 中的图像 1,2 Etekcity Lasergrip 1080 Button Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Button Replacement: 步骤 6 中的图像 1,1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Button Replacement: 步骤 7 中的图像 1,2 Etekcity Lasergrip 1080 Button Replacement: 步骤 7 中的图像 2,2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Button Replacement: 步骤 8 中的图像 1,1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
结论
团队
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S5G1
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 488
