跳转到主内容
Esteban Crystal Heart Strings Replacement
你所需要的
  1. Esteban Crystal Heart Strings Replacement, Removing the damaged strings from the head: 步骤 1 中的图像 1,3 Esteban Crystal Heart Strings Replacement, Removing the damaged strings from the head: 步骤 1 中的图像 2,3 Esteban Crystal Heart Strings Replacement, Removing the damaged strings from the head: 步骤 1 中的图像 3,3
    • On the head of the guitar, unroll the string from its tuning peg.
    • Once the string is unrolled, remove the string by sliding it out of the small hole in its tuning peg.
  2. Esteban Crystal Heart Strings Replacement, Removing the string from the bridge: 步骤 2 中的图像 1,3 Esteban Crystal Heart Strings Replacement, Removing the string from the bridge: 步骤 2 中的图像 2,3 Esteban Crystal Heart Strings Replacement, Removing the string from the bridge: 步骤 2 中的图像 3,3
    • Remove the peg from the bridge but pulling it out of its hole.
    • Pull the string out of the hole.
  3. Esteban Crystal Heart Strings Replacement, Inserting the new string on the bridge.: 步骤 3 中的图像 1,3 Esteban Crystal Heart Strings Replacement, Inserting the new string on the bridge.: 步骤 3 中的图像 2,3 Esteban Crystal Heart Strings Replacement, Inserting the new string on the bridge.: 步骤 3 中的图像 3,3
    • Insert the end of the string with the small hole in it in the opened peg in the bridge.
    • Start to insert the peg in the hole with the string under it.
    • Push the peg down tightly to make sure that the string will not pop out when enough resistance is put in it.
  4. Esteban Crystal Heart Strings Replacement, Inserting the new string in the head: 步骤 4 中的图像 1,3 Esteban Crystal Heart Strings Replacement, Inserting the new string in the head: 步骤 4 中的图像 2,3 Esteban Crystal Heart Strings Replacement, Inserting the new string in the head: 步骤 4 中的图像 3,3
    • Pull the string and line it around the tuning peg, underneath the hole. Make sure that the resistance is pretty strong.
    • Wrap the remaining strings on the tuning peg about 5 or 6 times.
    • Slide the remaining end of the string through the hole and hold it in place.
  5. Esteban Crystal Heart Strings Replacement, Tightening the string: 步骤 5 中的图像 1,3 Esteban Crystal Heart Strings Replacement, Tightening the string: 步骤 5 中的图像 2,3 Esteban Crystal Heart Strings Replacement, Tightening the string: 步骤 5 中的图像 3,3
    • Twist the tuning peg to the right to tighten it.
    • Make sure that the string has enough resistance that when it is strummed, there is a tone.
  6. Esteban Crystal Heart Strings Replacement, Tuning the guitar in its correct sound: 步骤 6 中的图像 1,3 Esteban Crystal Heart Strings Replacement, Tuning the guitar in its correct sound: 步骤 6 中的图像 2,3 Esteban Crystal Heart Strings Replacement, Tuning the guitar in its correct sound: 步骤 6 中的图像 3,3
    • You can use a tuner by just playing each string in front of it and then just turn the fasteners until the tuner shows that the sound matches its appropriate sound.
    • Another way is by ear, press down on the fifth fret and the preceding string in which you are trying to tune. For example, if you are tuning the high E string, press down the B string, 5th fret.
    • Strumming the B stringwhile pressing down on the 5th fret should make the sound of open E string.
    • Match the sounds of both strings and this will tune the high E string.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 1-5, Donnelly Fall 2014 USF Tampa, Team 1-5, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G5
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 11
总计 1,096
