跳转到主内容
Escort Passport Max2 Lens Replacement
你所需要的
  1. Escort Passport Max2 Lens Replacement, Exterior Case: 步骤 1 中的图像 1,2 Escort Passport Max2 Lens Replacement, Exterior Case: 步骤 1 中的图像 2,2
    • Inser the flat end of a spudger into one of the two notches and pry off the case.
  2. Escort Passport Max2 Lens Replacement: 步骤 2 中的图像 1,2 Escort Passport Max2 Lens Replacement: 步骤 2 中的图像 2,2
    • Slide the spudger around the perimeter of the radar housing until the case separates.
  3. Escort Passport Max2 Lens Replacement: 步骤 3 中的图像 1,2 Escort Passport Max2 Lens Replacement: 步骤 3 中的图像 2,2
    • Repeat these steps to remove the other side.
  4. Escort Passport Max2 Lens Replacement, Lens: 步骤 4 中的图像 1,2 Escort Passport Max2 Lens Replacement, Lens: 步骤 4 中的图像 2,2
    • Remove the four 9mm Phillips #1 screws from the bottom of the radar.
    • Remove the bottom case.
  5. Escort Passport Max2 Lens Replacement: 步骤 5 中的图像 1,1
    • Gently spread apart the thin silver frame that wraps around the device and remove the dark purple lens.
    • The silver frame can easily pop off of the device now that the bottom metal case has been removed. Don't worry if it comes off all the way. It can easily be put back in it's place.
结论
团队
UW Tacoma, Team S1-G1, Liner Spring 2018 UW Tacoma, Team S1-G1, Liner Spring 2018 的会员
UWT-LINER-S18S1G1
5 名成员
创作了4篇指南
一条评论
Where can I buy a replacement lens?
Kit - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 356
