跳转到主内容
Equity Alarm Clock 13014 Alarm Switch Replacement
你所需要的
  1. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: 步骤 1 中的图像 1,3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: 步骤 1 中的图像 2,3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: 步骤 1 中的图像 3,3
    • Remove the battery door using your finger nail or an opening tool.
  2. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: 步骤 2 中的图像 1,2 Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
  3. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove Cover: 步骤 3 中的图像 1,1
    • Remove the back cover gently.
    • DO NOT pull the back cover off quickly or you may damage the wires connected.
  4. Equity Alarm Clock 13014 Alarm Switch Replacement: 步骤 4 中的图像 1,2 Equity Alarm Clock 13014 Alarm Switch Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the small screw located above the alarm switch.
    • Remove the small screw located below the alarm switch as well.
  5. Equity Alarm Clock 13014 Alarm Switch Replacement: 步骤 5 中的图像 1,2 Equity Alarm Clock 13014 Alarm Switch Replacement: 步骤 5 中的图像 2,2
    • Place the end of the soldering iron on the end of the wire connected to the copper cylinder to detach the wire.
    • If you are unfamiliar with soldering, take a look at this article: How to Solder and Desolder Connections.
    • To replace the alarm switch, attach one end of new alarm switch wire to the copper cylinder.
    • Use a Phillips #1 screwdriver to reinstall the switch screws.
    • Follow steps in reverse order to assemble the clock.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 1,085
