跳转到主内容
Epson VS240 Speaker Replacement
你所需要的
  1. Epson VS240 Speaker Replacement, Shell: 步骤 1 中的图像 1,3 Epson VS240 Speaker Replacement, Shell: 步骤 1 中的图像 2,3 Epson VS240 Speaker Replacement, Shell: 步骤 1 中的图像 3,3
    • Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
    • The captive screw will loosen, but it cannot be fully removed.
    • Slide the panel off and remove it from the device.
  2. Epson VS240 Speaker Replacement: 步骤 2 中的图像 1,2 Epson VS240 Speaker Replacement: 步骤 2 中的图像 2,2
    • Use the Phillips #2 screwdriver to remove the three 5 mm screws.
    • Using the same Phillips #2 screwdriver, remove the single 8 mm silver screw.
  3. Epson VS240 Speaker Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the two 10 mm silver screws from the bottom of the device.
  4. Epson VS240 Speaker Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the single 10 mm screw where the panel was removed in Step 1.
    • Remove the white back plate from the device.
  5. Epson VS240 Speaker Replacement: 步骤 5 中的图像 1,3 Epson VS240 Speaker Replacement: 步骤 5 中的图像 2,3 Epson VS240 Speaker Replacement: 步骤 5 中的图像 3,3
    • Flip the projector over so that the underside (side with the feet) is facing you.
    • Use a Phillips #1 screwdriver to remove five 10 mm screws on the underside of projector.
    • Using the same Phillips #1 screwdriver, remove a single 10 mm screw in the center hole.
    • You may need to use a screwdriver extender to reach the single screw.
  6. Epson VS240 Speaker Replacement: 步骤 6 中的图像 1,3 Epson VS240 Speaker Replacement: 步骤 6 中的图像 2,3 Epson VS240 Speaker Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove two 10 mm screws from the openings on each side of the air filter, on the topside of the projector.
    • You may need to use a screwdriver extender to reach the two screws.
    • Using the same Phillips #1 screwdriver, remove the two 10 mm screws where the white panel was removed on the topside of the projector in Step 1.
  7. Epson VS240 Speaker Replacement: 步骤 7 中的图像 1,2 Epson VS240 Speaker Replacement: 步骤 7 中的图像 2,2
    • Be careful when removing the top cover of projector as there is as white ribbon cable connecting it to the motherboard.
    • Gently lift top cover and place it on its top next to the projector so that the ribbon has no tension on it.
    • Gently pull the brown tape connecting the cable to the motherboard and then remove the shell from the device.
  8. Epson VS240 Speaker Replacement, Speaker: 步骤 8 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the two 7 mm screws holding the speaker to the device.
  9. Epson VS240 Speaker Replacement: 步骤 9 中的图像 1,1
    • Unplug the wire combination of red, black, and white wires from the motherboard using a spudger or fingernail.
    • Lift and remove the speaker from the device.
结论
Edward O'Neil
于10/05/21注册
85 声望
撰写一个指南
团队
Clemson, Team 5-3, Hunter Fall 2021 Clemson, Team 5-3, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S5G3
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 148
