简介
The speaker of the projector is important as it allows for audio to be played so that a movie or video can be heard along with the projections from the projector. If your Epson VS240 has an issue with its built-in speaker system, use this guide to remove and replace the speaker. If the Epson VS240 projector speaker must be replaced, follow this guide to remove and replace the speaker. The speaker is easy to reach from the outside but it possess a wire that connects to the motherboard that must be reached.
你所需要的
Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
Slide the panel off and remove it from the device.
Using the Phillips #1 screwdriver, remove the two 7 mm screws holding the speaker to the device.
