跳转到主内容
Epson VS240 Bulb Replacement
你所需要的
  1. Epson VS240 Bulb Replacement, Bulb: 步骤 1 中的图像 1,2 Epson VS240 Bulb Replacement, Bulb: 步骤 1 中的图像 2,2
    • Unplug the device and let it cool for an hour.
    • Place the device on a flat surface.
  2. Epson VS240 Bulb Replacement: 步骤 2 中的图像 1,2 Epson VS240 Bulb Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #2 screwdriver, loosen the single screw securing the lamp cover.
    • Be careful of broken glass in the case that your bulb has been broken.
    • If there is broken glass, carefully shake the device to get the shards of glass on a piece of paper. Carefully dispose of the paper with the glass shards on it.
  3. Epson VS240 Bulb Replacement: 步骤 3 中的图像 1,2 Epson VS240 Bulb Replacement: 步骤 3 中的图像 2,2
    • Carefully slide the cover and lift it off the device.
    • Again, be careful of any broken parts within the device.
  4. Epson VS240 Bulb Replacement: 步骤 4 中的图像 1,3 Epson VS240 Bulb Replacement: 步骤 4 中的图像 2,3 Epson VS240 Bulb Replacement: 步骤 4 中的图像 3,3
    • Use the Phillips #2 screwdriver to loosen the screws attaching the bulb to the projector.
    • You only need to loosen the screws since they do not remove from the bulb completely.
  5. Epson VS240 Bulb Replacement: 步骤 5 中的图像 1,2 Epson VS240 Bulb Replacement: 步骤 5 中的图像 2,2
    • Once the bulb has been loosened, grab the raised section of the bulb and carefully lift the bulb up and away from the device.
结论
Be gentle when inserting the new bulb. If you feel any resistance when inserting the replacement bulb, chances are that you inserted it the wrong way. This is a common mistake. Turn it around, making it face the right direction, before again inserting it into the device.
Be careful when screwing components back into the device since over-screwing can result in damage to the pieces.
Toni Brennan
于09/28/21注册
121 声望
撰写一个指南
团队
Clemson, Team 5-3, Hunter Fall 2021 Clemson, Team 5-3, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S5G3
5 名成员
创作了6篇指南
一条评论
I replaced the bulb in the projector, but it still won't operate, and when I removed and reinstalled a bulb in my other projector, it does the same thing now, How do I fix it even with a replacement bulb?
Derrick A Durham - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 8
过去 30 天: 9
总计 286
