跳转到主内容
Epson Stylus Photo 820 Ink Cartridges Replacement
  1. Epson Stylus Photo 820 Ink Cartridges Replacement, Ink Cartridges: 步骤 1 中的图像 1,1
    • When you are low on ink your green power light will be flashing and your error light will stay a solid red.
  2. Epson Stylus Photo 820 Ink Cartridges Replacement: 步骤 2 中的图像 1,2 Epson Stylus Photo 820 Ink Cartridges Replacement: 步骤 2 中的图像 2,2
    • Lift the printer window open by pulling up on the tab.
    • Your printer should now be in the same state as shown in the second picture.
  3. Epson Stylus Photo 820 Ink Cartridges Replacement: 步骤 3 中的图像 1,2 Epson Stylus Photo 820 Ink Cartridges Replacement: 步骤 3 中的图像 2,2
    • Press the button on the far right to get your ink cartridge holders to slide over. (See the second picture)
  4. Epson Stylus Photo 820 Ink Cartridges Replacement: 步骤 4 中的图像 1,3 Epson Stylus Photo 820 Ink Cartridges Replacement: 步骤 4 中的图像 2,3 Epson Stylus Photo 820 Ink Cartridges Replacement: 步骤 4 中的图像 3,3
    • Press the tabs with the upward facing arrows to open the hatches as shown in the first picture.
    • Remove the ink cartridge(s) that needs to be replaced. The black cartridge is on the left and the color cartridge is on the right.
    • Make sure your cartridges are the same as the ones shown in the third picture. Non-Epson ink cartridges may not be recognized by your printer.
  5. Epson Stylus Photo 820 Ink Cartridges Replacement: 步骤 5 中的图像 1,3 Epson Stylus Photo 820 Ink Cartridges Replacement: 步骤 5 中的图像 2,3 Epson Stylus Photo 820 Ink Cartridges Replacement: 步骤 5 中的图像 3,3
    • Insert your new ink cartridges and close the hatches.
    • Close your printer door and push the ink cartridge button on the far right and again.
    • After your ink charges you're ready to print!
终点
另外一个人完成了本指南。
Alex Lin
于04/10/11注册
99 声望
创作了3篇指南
团队
Cal Poly, Team 20-68, Walters Spring 2011 Cal Poly, Team 20-68, Walters Spring 2011 的会员
CPSU-WALTERS-S11S20G68
4 名成员
创作了12篇指南
一条评论
I pushed the 3rd button so the cartridge holder will slide over, it will not move.
I tried unplugging the printer and plugging it back in & repower it up. still 'stuck' to the right.
I need to change the black ink. can you help? thank you!
tina - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 2,898
