跳转到主内容
Epson Stylus Photo 1400 Printhead Replacement
你所需要的
  1. Epson Stylus Photo 1400 Printhead Replacement, Housing: 步骤 1 中的图像 1,1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Printhead Replacement: 步骤 2 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 2 中的图像 2,2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
    errore avevo chiesto informazioni x sostituire la batteria al cellulare HUAWEI Mod. LX1
    Luigi Martinenghi - 回复
    avevo chiesto informazioni x la sostituzione della batteria cellulare HUAWEI Mod.LX1
  3. Epson Stylus Photo 1400 Printhead Replacement: 步骤 3 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Printhead Replacement: 步骤 4 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 4 中的图像 2,2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Printhead Replacement: 步骤 5 中的图像 1,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 5 中的图像 2,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 5 中的图像 3,3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Printhead Replacement: 步骤 6 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 6 中的图像 2,2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Printhead Replacement: 步骤 7 中的图像 1,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 7 中的图像 2,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 7 中的图像 3,3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Printhead Replacement: 步骤 8 中的图像 1,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 8 中的图像 2,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 8 中的图像 3,3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Printhead Replacement: 步骤 9 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 9 中的图像 2,2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Printhead Replacement: 步骤 10 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 10 中的图像 2,2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Printhead Replacement: 步骤 11 中的图像 1,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 11 中的图像 2,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 11 中的图像 3,3
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Printhead Replacement: 步骤 12 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 12 中的图像 2,2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
    this is where I get stuck. the top won't come off. it seems to be stuck at the right front corner, where the buttons are. Is the button grouping part of the upper housing or does it come separate from the upper housing unit. The picture appears that you are taking the button attachment as part of the upper housing unit. But it is really stuck there on my 1400.
    1gr8nana - 回复
  13. Epson Stylus Photo 1400 Printhead Replacement, Printhead: 步骤 13 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement, Printhead: 步骤 13 中的图像 2,2
    • Insert a flathead screwdriver into the hole on the right side of the frame.
    • Turn the screwdriver counterclockwise until it stops.
    insert a flathead screwdriver into the hole on the right side of the frame.
    Rotate screwdriver counter clockwise until it stops. here is a question what does it mean when the plastic screw never stops? or gets tight, and just keeps spinning?
    joe - 回复
    ok i removed the printhead to clean it, but once mounted back, the printer doesnt recognize the cartridges anymore. how do you think i can fix that ?
    beubz - 回复
    I think there is a program needed to connect the head with the min board. I have seen it available but now I am looking I cant find it myself now....arrrggggg
    andy -
  14. Epson Stylus Photo 1400 Printhead Replacement: 步骤 14 中的图像 1,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 14 中的图像 2,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 14 中的图像 3,3
    • Move the carriage unit to the center.
  15. Epson Stylus Photo 1400 Printhead Replacement: 步骤 15 中的图像 1,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 15 中的图像 2,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 15 中的图像 3,3
    • Open the cartridge cover.
    • Remove all the ink cartridges inside.
  16. Epson Stylus Photo 1400 Printhead Replacement: 步骤 16 中的图像 1,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 16 中的图像 2,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 16 中的图像 3,3
    • Using a plastic opening tool, disengage the two upper tab on the side of the carriage unit.
    • With a spudger or plastic opening tool, disengage the lower tab.
  17. Epson Stylus Photo 1400 Printhead Replacement: 步骤 17 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 17 中的图像 2,2
    • Slide the cover upward and rotate it around the hinge by 90°.
  18. Epson Stylus Photo 1400 Printhead Replacement: 步骤 18 中的图像 1,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 18 中的图像 2,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 18 中的图像 3,3
    • The CSIC assembly sits inside the carriage unit.
    • Reaching from the back of the carriage unit, disengage the two tabs that hold the CSIC assembly in place.
    • The tabs can be difficult to disengage. The second image shows the rear of CSIC assembly.
    • The third image shows where the tabs lock onto the carriage unit.
    • Remove the CSIC assembly from the carriage unit.
  19. Epson Stylus Photo 1400 Printhead Replacement: 步骤 19 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 19 中的图像 2,2
    • Using tweezers, disengage the right tab from the back right panel of the carriage unit.
    • Push the tweezers towards the front of the printer while pulling up on the right panel.
    • When the tab is disengaged, you can pull the panel upwards slightly to prevent the tab from engaging.
  20. Epson Stylus Photo 1400 Printhead Replacement: 步骤 20 中的图像 1,1
    • Using the tweezers, disengage the left tab from the back left.
    • Push the tweezers towards the front of the printer while pulling on the left side upwards.
    • When both tabs are disengaged, the part is slightly raised.
    An easier way is if you have a hooked ‘weeding tool’ or hooked tweezers etc - there is a small hole near the bottom left corner of the yellow box in the picture. You can get the point of the hook in there and hook it forward to unclip it. I did this on both sides - worked a charm!
    Simple ASCII diagram of clip from the side - (it goes up and clips over the top to the rear of the printer)
    (rear) /^
    I <- the hole will let you get in the side of here, pull forward to unclip.
    I
    \ ——-(print head, ink compartment)——
    Scott Esplin - 回复
    Sorry ASCII didn't turn out very good!
    The tilde ‘^’ should be immediately above the capital ‘I’ in the line below.
    Scott Esplin - 回复
    A much easier way I found is to, slide the carriage to the left and stick a screw driver from the gap on the chassis just above the motor on the left and push to disingage, and then repeat the process for the right starting with pulling the carriage to the right.
    Kingsley Tafon - 回复
  21. Epson Stylus Photo 1400 Printhead Replacement: 步骤 21 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 21 中的图像 2,2
    • Lift CSIC assembly up and out of the Carriage Unit.
  22. Epson Stylus Photo 1400 Printhead Replacement: 步骤 22 中的图像 1,1
    • The printhead is the part with 6 nozzles.
    • Remove the three 8 mm #2 Phillips screws that secure the printhead.
  23. Epson Stylus Photo 1400 Printhead Replacement: 步骤 23 中的图像 1,2 Epson Stylus Photo 1400 Printhead Replacement: 步骤 23 中的图像 2,2
    • Remove the printhead from the carriage unit by lifting it up vertically.
  24. Epson Stylus Photo 1400 Printhead Replacement: 步骤 24 中的图像 1,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 24 中的图像 2,3 Epson Stylus Photo 1400 Printhead Replacement: 步骤 24 中的图像 3,3
    • Disconnect the two ribbon cables on the back of the printhead.
    Thank you ! great write up. Step 18: difficult was a understatement.
    Thanks again R.L.
    lair.roger - 回复
结论
20等其他人完成本指南。
Larry Huang
于10/12/11注册
1,004 声望
创作了4篇指南
团队
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G11
4 名成员
创作了12篇指南
15条评论
Dear Larry,
Thank you for your excellent, thorough guide.
Since all I am replacing is the printhead, why do I need to remove the covers from the printer? In the later steps, you show clearly how to remove the printhead directly from the top front of the printer. Isn't that all I have to do to remove and replace the printhead?
After replacing the printhead on the Epson 1400, do I need to do some special kind of reset?
Thanks very much for your help and attention.
CalFox - 回复
By default, the cartridge box is on the right most side of the printer. To get the printhead out, you need to disengage two tabs on the back of the cartridge box, shown on step 18. It's impossible to get to the right side one unless you can move the cartridge box close to the middle. And by default, you can't move the cartridge box by hand unless you unlock it on step 13, which is inside the side housing. If you can get away with sticking your hand inside the small rectangular hole of the top housing, then you don't have to take it off. But it's very difficult to maneuver your tweezers without lots of room. It's a tricky and awkward motion for your hand to disengage it, so we took off the housing first.
I'm not sure if any resets need to be done. You might have to realign the printhead using the printer software after you install it if the prints turn out strange.
Larry Huang -
With a simple hooked-end machinists scribe, it was easy to gently lift each little tab forward from the front and then easily lift the back board (over the printhead screws) straight up.
All I needed to do to let the printhead be moveable is turn the unit off, then turn it on. The printhead moves to center, then unplug the unit. Now the printhead is easy to move.
This "unplug it" method is common to most CISS retrofits to most Epson printers and it is not supposed to hurt anything.
Jon
CalFox - 回复
I think Calfox is right - just turn printer on, then unplug as carriage starts to move. Then it can be moved freely.
Also a 4 - 5 mm Allen key can be used to unhook the CSIC plate - place angled end of key behind carriage, & feel for the edge of the clip. Then pull forward on allen key, & up on the CSIC plate. Do both sides. Take care not to damage the encoder strip.
Will try scribe method next -
Stuart - 回复
So, I have the Epson Photo Stylus 1400 too. Mine was in storage for almost a year. When I tried to use it again, it didn't recognize that there was any ink in the cartridges. I replaced the cartridges and still didn't recognize that there was ink in the cartridges. I tried to clean it from the maintenance menu, but no luck. Any ideas on what I can do?
Jason cLYBURN - 回复
Excellent Guide.
Can you show something about how to unclog clogged printhead
jaiswalnilesh - 回复
Everyone, save yourself a lot of trouble and start from Step 15. There is no need to remove the casing. I've replaced this print head before and did it successfully while keeping the casing intact. Another tool that can help remove the CSIC assembly is those metal picture frame hooks that have a sharp end on one side and a hook on the other. Looks like a huge fish hook. Just bend it open a little bit to give it a bit of an angle and it fits right in there.
donttakecash - 回复
Where can I buy the needed printhead for replacing?
cobbra31 - 回复
Thank you very much, your contribution is very appreciated.
Sharing - 回复
What's the number of epson 1400 printhead
Fiaz - 回复
Can anybody tell the printhead number of epson 1400
Fiaz - 回复
Hello ,can somebody help me out from this my printer epson 1400,the red ink light,red paper light is flashing and the power button is off. Is there any body that can help me out
Sajo olatunbosun - 回复
Hello
SORRY FOR MY ENGLISH…
I tried to change the print head before knowing your post ...
After finish replacing the printhead, the printer stops working and beeps discontinus when I plug in the power cable, and the power button is off.
I encountered difficulties to relocate the tab on the side of the carriage unit (see on step 16)
Please
Does anyone have an explanation for this?
Thank you in advance.
Damien
(FRANCE)
Damien DAVID - 回复
I don’t know if you were able to fix the problem with your EPSON 1400, but if you did I would greatly appreciate it if you could let me know how it was done. This is the exact problem I am experiencing with my 1400
Joel -
Question, anyone know if thers’s is a “belt” that operates the ink housing and how you would replace it? Looking to buy some used 1400’s and seller described the issue like this to me.
Angela Fleak - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 30
过去 30 天: 125
总计 42,739
