跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement
你所需要的
  1. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Housing: 步骤 1 中的图像 1,1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 2 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 2 中的图像 2,2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 3 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 4 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 4 中的图像 2,2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 5 中的图像 1,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 5 中的图像 2,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 5 中的图像 3,3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 6 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 6 中的图像 2,2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 7 中的图像 1,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 7 中的图像 2,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 7 中的图像 3,3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 8 中的图像 1,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 8 中的图像 2,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 8 中的图像 3,3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 9 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 9 中的图像 2,2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 10 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 10 中的图像 2,2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 11 中的图像 1,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 11 中的图像 2,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 11 中的图像 3,3
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 12 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 12 中的图像 2,2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
  13. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Paper Eject Frame Assembly: 步骤 13 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement, Paper Eject Frame Assembly: 步骤 13 中的图像 2,2
    • Hold the ink tube and draw out the waste ink tube by pulling on both tubes in opposite directions.
  14. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 14 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 14 中的图像 2,2
    • Remove the acetate tape that secure the connector cable.
  15. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 15 中的图像 1,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 15 中的图像 2,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 15 中的图像 3,3
    • There are six screws that secure the printer mechanism.
    • Using the #2 Phillips screwdriver, remove the three 10mm screws shown.
  16. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 16 中的图像 1,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 16 中的图像 2,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 16 中的图像 3,3
    • Using the #2 Phillips screwdriver, remove the last three 10mm screws securing the printer mechanism.
  17. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 17 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 17 中的图像 2,2
    • Remove printer mechanism from lower housing by holding the handles and lifting it upwards.
  18. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 18 中的图像 1,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 18 中的图像 2,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 18 中的图像 3,3
    • Remove the CD-R unit housing by releasing the two attaching points to the tray base.
    • Pull it outwards diagonally one side at a time.
  19. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 19 中的图像 1,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 19 中的图像 2,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 19 中的图像 3,3
    • Remove the left frame support plate by removing the two 6mm screws that secure it.
    • Pull it out by hand to free it.
  20. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 20 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 20 中的图像 2,2
    • Using the #2 Phillips screwdriver, remove the four 6mm screws.
    • Remove the two 8mm screws.
    • The screws are located on the lower sections of the printer.
  21. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 21 中的图像 1,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 21 中的图像 2,3 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 21 中的图像 3,3
    • Two guide pins secure the paper EJ assy in place.
    • Remove the two guide pins on the CD/DVD tray base by pulling each pin outward.
  22. Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 22 中的图像 1,2 Epson Stylus Photo 1400 Paper Eject Frame Assembly Replacement: 步骤 22 中的图像 2,2
    • Remove the paper EJ frame assy by pulling the it towards you.
结论
41等其他人完成本指南。
Larry Huang
于10/12/11注册
1,004 声望
创作了4篇指南
团队
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G11
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 56
总计 21,045
