跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide shows how to replace an Ink Cartridge. This process requires no necessary tools or knowledge of the device.
工具
没有特定工具。
  1. Open cover of the printer. Open the cartridge cover by pressing down on the tab and lifting it up.
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  3. Grab the sides of the ink cartridge and pull it out. Replace ink cartridge with brand new ink cartridge.
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  4. Close cartridge cover. Close cover of the printer.
    • Close cartridge cover.
    • Close cover of the printer.
结论
另外一个人完成了本指南。
Larry Huang
于2011年10月12日注册
806 信誉积分
创作了4篇指南
团队
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G11
4 名成员
创作了6篇指南
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - 回复
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - 回复
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - 回复
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 25
总计 8,385
