跳转到主内容
Epson Stylus Photo 1400 Ink cartridge replacement
你所需要的
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: 步骤 1 中的图像 1,2 Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: 步骤 1 中的图像 2,2
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: 步骤 2 中的图像 1,2 Epson Stylus Photo 1400 Ink cartridge replacement: 步骤 2 中的图像 2,2
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: 步骤 3 中的图像 1,2 Epson Stylus Photo 1400 Ink cartridge replacement: 步骤 3 中的图像 2,2
    • Close cartridge cover.
    • Close cover of the printer.
结论
2等其他人完成本指南。
Larry Huang
于10/12/11注册
1,004 声望
创作了4篇指南
团队
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G11
4 名成员
创作了12篇指南
5条评论
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - 回复
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - 回复
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - 回复
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - 回复
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 21
总计 10,067
