跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Epson Stylus Photo 1400 Housing Replacement
你所需要的
  1. Epson Stylus Photo 1400 Housing Replacement, Housing: 步骤 1 中的图像 1,1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Housing Replacement: 步骤 2 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 2 中的图像 2,2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Housing Replacement: 步骤 3 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Housing Replacement: 步骤 4 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 4 中的图像 2,2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Housing Replacement: 步骤 5 中的图像 1,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 5 中的图像 2,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 5 中的图像 3,3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Housing Replacement: 步骤 6 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 6 中的图像 2,2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Housing Replacement: 步骤 7 中的图像 1,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 7 中的图像 2,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 7 中的图像 3,3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Housing Replacement: 步骤 8 中的图像 1,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 8 中的图像 2,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 8 中的图像 3,3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Housing Replacement: 步骤 9 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 9 中的图像 2,2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Housing Replacement: 步骤 10 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 10 中的图像 2,2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Housing Replacement: 步骤 11 中的图像 1,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 11 中的图像 2,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 11 中的图像 3,3
    • Disconnect the cable on the side by carefully pulling it outwards.
    • You may need to gently rock the cable up and down while pulling.
  12. Epson Stylus Photo 1400 Housing Replacement: 步骤 12 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 12 中的图像 2,2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
结论
10等其他人完成本指南。
Larry Huang
于10/12/11注册
1,004 声望
创作了4篇指南
团队
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G11
4 名成员
创作了12篇指南
一条评论
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
ryan Caputo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 48
总计 7,582
