简介
To get to the inside parts of the printer, the housing components must come off.
你所需要的
Turn off the printer.
Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
Locate the IEEE cover in the back.
Gently slide the cover to the right to unlatch, then pull to remove it.
errore avevo chiesto informazioni x sostituire la batteria al cellulare HUAWEI Mod. LX1
avevo chiesto informazioni x la sostituzione della batteria cellulare HUAWEI Mod.LX1
Remove the upper housing by lifting it upwards.
this is where I get stuck. the top won't come off. it seems to be stuck at the right front corner, where the buttons are. Is the button grouping part of the upper housing or does it come separate from the upper housing unit. The picture appears that you are taking the button attachment as part of the upper housing unit. But it is really stuck there on my 1400.
10等其他人完成本指南。
一条评论
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
