跳转到主内容
Epson Stylus Photo 1400 Housing Replacement
你所需要的
  1. Epson Stylus Photo 1400 Housing Replacement, Housing: 步骤 1 中的图像 1,1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Housing Replacement: 步骤 2 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 2 中的图像 2,2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
    errore avevo chiesto informazioni x sostituire la batteria al cellulare HUAWEI Mod. LX1
    Luigi Martinenghi - 回复
    avevo chiesto informazioni x la sostituzione della batteria cellulare HUAWEI Mod.LX1
  3. Epson Stylus Photo 1400 Housing Replacement: 步骤 3 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Housing Replacement: 步骤 4 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 4 中的图像 2,2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Housing Replacement: 步骤 5 中的图像 1,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 5 中的图像 2,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 5 中的图像 3,3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Housing Replacement: 步骤 6 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 6 中的图像 2,2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Housing Replacement: 步骤 7 中的图像 1,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 7 中的图像 2,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 7 中的图像 3,3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Housing Replacement: 步骤 8 中的图像 1,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 8 中的图像 2,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 8 中的图像 3,3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Housing Replacement: 步骤 9 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 9 中的图像 2,2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Housing Replacement: 步骤 10 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 10 中的图像 2,2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Housing Replacement: 步骤 11 中的图像 1,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 11 中的图像 2,3 Epson Stylus Photo 1400 Housing Replacement: 步骤 11 中的图像 3,3
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Housing Replacement: 步骤 12 中的图像 1,2 Epson Stylus Photo 1400 Housing Replacement: 步骤 12 中的图像 2,2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
    this is where I get stuck. the top won't come off. it seems to be stuck at the right front corner, where the buttons are. Is the button grouping part of the upper housing or does it come separate from the upper housing unit. The picture appears that you are taking the button attachment as part of the upper housing unit. But it is really stuck there on my 1400.
    1gr8nana - 回复
结论
10等其他人完成本指南。
Larry Huang
于10/12/11注册
1,004 声望
创作了4篇指南
团队
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G11
4 名成员
创作了12篇指南
一条评论
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
ryan Caputo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 7,543
