跳转到主内容
Epson Stylus NX305 Scanner Motor Replacement
你所需要的
  1. Epson Stylus NX305 Scanner Motor Replacement, Scanner Motor: 步骤 1 中的图像 1,1
    • Make sure that the printer is not plugged in before working on it.
    • Orient the printer so that the back of it is facing you.
  2. Epson Stylus NX305 Scanner Motor Replacement: 步骤 2 中的图像 1,1
    • Locate the 3mm Phillips #0 screw that is on the right-hand side of the printer.
    • Using a Phillips head screwdriver, remove the screw.
  3. Epson Stylus NX305 Scanner Motor Replacement: 步骤 3 中的图像 1,2 Epson Stylus NX305 Scanner Motor Replacement: 步骤 3 中的图像 2,2
    • Open up the lid of the printer.
    • With the printer facing away from you, lift up on the right hand side of the lid of the printer and slide it to the left to remove it.
    • Be careful not to remove the white ribbon and wires that are connected.
  4. Epson Stylus NX305 Scanner Motor Replacement: 步骤 4 中的图像 1,1
    • With the printer facing you, open the lid of the scanner to expose the 3mm Phillips #0 screw at the top left of the scanner.
  5. Epson Stylus NX305 Scanner Motor Replacement: 步骤 5 中的图像 1,1
    • Locate the six 3mm Phillips #2 screws under the lid of the printer and remove them.
  6. Epson Stylus NX305 Scanner Motor Replacement: 步骤 6 中的图像 1,1
    • Locate the three clips on the front side of the printer lid.
    • Use the plastic opening tool to release the clips and carefully pry open the lid.
  7. Epson Stylus NX305 Scanner Motor Replacement: 步骤 7 中的图像 1,1
    • Locate the belt that is attached to the scanner motor and remove it by carefully stretching off of the gear.
  8. Epson Stylus NX305 Scanner Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the two 3mm Phillips #2 screws from the scanner motor assembly.
    • Carefully lift the scanner motor assembly out of the housing making sure not to damage the wiring.
  9. Epson Stylus NX305 Scanner Motor Replacement: 步骤 9 中的图像 1,1
    • Flip over the scanner motor assembly to expose the scanner motor.
    • Remove the two 3mm Phillips #2 screws from the assembly and remove the motor.
结论
Jeffrey Barnett
于09/21/14注册
101 声望
撰写一个指南
团队
USF Tampa, Team 1-2, Donnelly Fall 2014 USF Tampa, Team 1-2, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G2
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 468
