跳转到主内容
Epson Stylus NX240 Side Buttons Replacement
你所需要的
  1. Epson Stylus NX240 Side Buttons Replacement, Side Buttons: 步骤 1 中的图像 1,2 Epson Stylus NX240 Side Buttons Replacement, Side Buttons: 步骤 1 中的图像 2,2
    • Go to the left side of the printer and locate the control panel with the buttons on it.
    • Take a plastic opening tool and stick it in the crack between the top of the panel and the body of the printer.
    • Pry the cover of the panel away from the body of the printer until the panel releases from the body of the printer.
  2. Epson Stylus NX240 Side Buttons Replacement: 步骤 2 中的图像 1,1
    • Carefully lift up the panel cover and turn it to its side so that the buttons are facing towards the rest of the printer.
    • Notice that the panel cover is attached to the printer with a ribbon cable. The ribbon cable must stay connected to the body of the printer or else the buttons will be unresponsive once replaced.
  3. Epson Stylus NX240 Side Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the six 3mm Phillips #2 screws connecting the control panel to the circuit board.
  4. Epson Stylus NX240 Side Buttons Replacement: 步骤 4 中的图像 1,1
    • After unscrewing, carefully lift the plastic part of the control panel away from the circuit board.
    • The plastic part of the control panel is now separate.
  5. Epson Stylus NX240 Side Buttons Replacement: 步骤 5 中的图像 1,1
    • Flip over the plastic part of the now separated control panel.
    • Remove the buttons by pulling them up with your fingers.
  6. Epson Stylus NX240 Side Buttons Replacement: 步骤 6 中的图像 1,1
    • All parts should be separate now to clean or replace.
结论
Joshua Fabel
于10/13/16注册
104 声望
撰写一个指南
团队
University of Maine, Team 2-4, Diaz Fall 2016 University of Maine, Team 2-4, Diaz Fall 2016 的会员
UMAINE-DIAZ-F16S2G4
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 569
