跳转到主内容
Epson Stylus NX230 Scanner Motor Replacement
你所需要的
  1. Epson Stylus NX230 Scanner Motor Replacement, Scanner Motor: 步骤 1 中的图像 1,1
    • Check that the printer is unplugged to prevent shock.
    • Turn the printer so the front buttons are facing away from you.
  2. Epson Stylus NX230 Scanner Motor Replacement: 步骤 2 中的图像 1,1
    • Locate the 3mm Phillips #0 screw in the top left corner of the printer.
    • Remove the screw using a Phillips head screwdriver.
    • Store the screw in a safe place where you can access them later.
  3. Epson Stylus NX230 Scanner Motor Replacement: 步骤 3 中的图像 1,1
    • Flip the top of the printer up so that you can see the inside of the printer.
    • There is a white ribbon cable in the right top corner of the printer.
    • Make sure that the white ribbon does not come detached from the right side of the printer.
  4. Epson Stylus NX230 Scanner Motor Replacement: 步骤 4 中的图像 1,1
    • Lay the scanner face up so you can access the under side, and place something, such as a piece of Styrofoam, underneath of it so that the white tape does not become detached.
    • Locate the four 3mm Phillips #2 screws along the edge, and remove all of them.
    • Store the screws in a safe place where you can access them later.
  5. Epson Stylus NX230 Scanner Motor Replacement: 步骤 5 中的图像 1,2 Epson Stylus NX230 Scanner Motor Replacement: 步骤 5 中的图像 2,2
    • Locate the seam on between outer shell of the printer and the inside of the printer.
    • Starting from the top of the printer, use the plastic opening tool to slowly pry the scanner apart along the seam.
  6. Epson Stylus NX230 Scanner Motor Replacement: 步骤 6 中的图像 1,2 Epson Stylus NX230 Scanner Motor Replacement: 步骤 6 中的图像 2,2
    • Detach the bottom of the scanner.
    • Flip the bottom of the scanner over so that it rests on top of the printer.
    • This gives you access to the motor.
  7. Epson Stylus NX230 Scanner Motor Replacement: 步骤 7 中的图像 1,1
    • Gently lift the scanner bar in order to remove it from the scanner.
    • Detach the white ribbon cable from the scanner bar.
  8. Epson Stylus NX230 Scanner Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the two 3mm Phillips #2 screws on the underside of the scanner bar attached to the silver motor.
    • Remove the motor from the scanner bar by gently pulling the motor upwards.
结论
Kimberly Pugel
于04/07/14注册
404 声望
创作了3篇指南
团队
Cal Poly, Team 6-1, Forte Spring 2014 Cal Poly, Team 6-1, Forte Spring 2014 的会员
CPSU-FORTE-S14S6G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 919
