跳转到主内容
Epson Stylus NX230 Motor Replacement
你所需要的
  1. Epson Stylus NX230 Motor Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Check to make sure the printer is unplugged to prevent electric shock.
  2. Epson Stylus NX230 Motor Replacement: 步骤 2 中的图像 1,2 Epson Stylus NX230 Motor Replacement: 步骤 2 中的图像 2,2
    • Align your printer so that the front buttons face to the right.
    • Remove the 3mm Phillips #2 screw in the hole in the top left corner. This screw attaches the side panel to the printer.
    • Store the screws in a safe place so you can access them later.
  3. Epson Stylus NX230 Motor Replacement: 步骤 3 中的图像 1,1
    • Flip and remove the top of the printer up so that you can see the inside.
    • There is a white strip in the top right corner of the printer called the ribbon cable.
    • Make sure that the ribbon cable does not detach from the printer to prevent damaging the connection.
  4. Epson Stylus NX230 Motor Replacement: 步骤 4 中的图像 1,2 Epson Stylus NX230 Motor Replacement: 步骤 4 中的图像 2,2
    • Align the printer so the front button panel faces to the right.
    • Remove the 3mm Phillips #2 screw on the side of the printer in the top left corner.
    • Store the screw in a safe place so you can access it later.
  5. Epson Stylus NX230 Motor Replacement: 步骤 5 中的图像 1,2 Epson Stylus NX230 Motor Replacement: 步骤 5 中的图像 2,2
    • Take the right side of the bar of plastic that runs across the top of the inside of the printer and push it towards the left side of the printer.
    • Take the left side of the bar and push it to the left and then to the right.
  6. Epson Stylus NX230 Motor Replacement: 步骤 6 中的图像 1,3 Epson Stylus NX230 Motor Replacement: 步骤 6 中的图像 2,3 Epson Stylus NX230 Motor Replacement: 步骤 6 中的图像 3,3
    • Using your hands, detach the side panel from the printer.
    • Take extra care with the locking mechanisms, which help keep the side panel on the printer.
    • You may need to use the plastic opening tools to pry apart the locking mechanisms.
  7. Epson Stylus NX230 Motor Replacement: 步骤 7 中的图像 1,1
    • Remove the two 3mm Phillips #2 screws attaching motherboard to the printer.
    • The motherboard can now be removed from the printer.
  8. Epson Stylus NX230 Motor Replacement, Motor: 步骤 8 中的图像 1,1
    • Remove the four 3mm Phillips #2 screws attaching the motor to the printer.
  9. Epson Stylus NX230 Motor Replacement: 步骤 9 中的图像 1,1
    • Place the printer on it's side so that the motherboard's location is facing up.
    • Push the motor up and out of the hole that it is in.
    • The motor will slide out of the hole at the top after that.
结论
Kimberly Pugel
于04/07/14注册
404 声望
创作了3篇指南
团队
Cal Poly, Team 6-1, Forte Spring 2014 Cal Poly, Team 6-1, Forte Spring 2014 的会员
CPSU-FORTE-S14S6G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 14
总计 962
