跳转到主内容
Epson PowerLite 83+ Projector Lens Replacement
你所需要的
  1. Epson PowerLite 83+ Projector Lens Replacement, Motherboard: 步骤 1 中的图像 1,3 Epson PowerLite 83+ Projector Lens Replacement, Motherboard: 步骤 1 中的图像 2,3 Epson PowerLite 83+ Projector Lens Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
    • A long shank Phillips #2 screwdriver is required to reach the screws.
  2. Epson PowerLite 83+ Projector Lens Replacement: 步骤 2 中的图像 1,3 Epson PowerLite 83+ Projector Lens Replacement: 步骤 2 中的图像 2,3 Epson PowerLite 83+ Projector Lens Replacement: 步骤 2 中的图像 3,3
    • Flip the projector over and lift the top cover from the rear of the projector.
    • Two cables are connected at the front that prevent full removal.
    • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
  3. Epson PowerLite 83+ Projector Lens Replacement: 步骤 3 中的图像 1,2 Epson PowerLite 83+ Projector Lens Replacement: 步骤 3 中的图像 2,2
    • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
    • Remove the ribbon cable from the connector and place the projector's top cover aside.
  4. Epson PowerLite 83+ Projector Lens Replacement: 步骤 4 中的图像 1,3 Epson PowerLite 83+ Projector Lens Replacement: 步骤 4 中的图像 2,3 Epson PowerLite 83+ Projector Lens Replacement: 步骤 4 中的图像 3,3
    • Remove the two 6 mm Phillips #2 screws.
    • Remove the single silver 5 mm Phillips #2 screw.
  5. Epson PowerLite 83+ Projector Lens Replacement: 步骤 5 中的图像 1,3 Epson PowerLite 83+ Projector Lens Replacement: 步骤 5 中的图像 2,3 Epson PowerLite 83+ Projector Lens Replacement: 步骤 5 中的图像 3,3
    • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
  6. Epson PowerLite 83+ Projector Lens Replacement: 步骤 6 中的图像 1,2 Epson PowerLite 83+ Projector Lens Replacement: 步骤 6 中的图像 2,2
    • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
  7. Epson PowerLite 83+ Projector Lens Replacement: 步骤 7 中的图像 1,2 Epson PowerLite 83+ Projector Lens Replacement: 步骤 7 中的图像 2,2
    • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
    • Lift the motherboard from the front side of the projector to clear the ribbon cables.
    • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
    • Remove the motherboard from the case.
  8. Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: 步骤 8 中的图像 1,3 Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: 步骤 8 中的图像 2,3 Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: 步骤 8 中的图像 3,3
    • Remove the four 6 mm Phillips #2 screws securing the fan bracket.
    • Remove the fan bracket by pulling straight up and set it aside.
  9. Epson PowerLite 83+ Projector Lens Replacement: 步骤 9 中的图像 1,3 Epson PowerLite 83+ Projector Lens Replacement: 步骤 9 中的图像 2,3 Epson PowerLite 83+ Projector Lens Replacement: 步骤 9 中的图像 3,3
    • Remove the four 6 mm Phillips #2 screws securing the projector lens.
  10. Epson PowerLite 83+ Projector Lens Replacement: 步骤 10 中的图像 1,2 Epson PowerLite 83+ Projector Lens Replacement: 步骤 10 中的图像 2,2
    • Unhook the JST connector wire from wire stay and move it aside.
    • Remove the projector lens from the base.
结论
Billy Fox
于02/22/22注册
467 声望
创作了3篇指南
团队
Clemson, Team 2-4, Hunter Spring 2022 Clemson, Team 2-4, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S2G4
4 名成员
创作了6篇指南
1指南评论
source for a replacement lens? I surely need one.
christopher wanko - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 22
总计 722
