跳转到主内容
Epson PowerLite 83+ Lamp Replacement
你所需要的
  1. Epson PowerLite 83+ Lamp Replacement, Lamp: 步骤 1 中的图像 1,1
    • Turn off and unplug the projector.
    • Allow the projector to cool for an hour before performing maintenance on it.
  2. Epson PowerLite 83+ Lamp Replacement: 步骤 2 中的图像 1,2 Epson PowerLite 83+ Lamp Replacement: 步骤 2 中的图像 2,2
    • Remove the 6 mm Phillips #2 screw securing the lamp cover.
  3. Epson PowerLite 83+ Lamp Replacement: 步骤 3 中的图像 1,3 Epson PowerLite 83+ Lamp Replacement: 步骤 3 中的图像 2,3 Epson PowerLite 83+ Lamp Replacement: 步骤 3 中的图像 3,3
    • Apply gentle pressure to the end of the lamp cover.
    • Pull the lamp cover towards the end of the projector.
    • When the cover is released, pull the cover straight up off of the projector to reveal the lamp.
  4. Epson PowerLite 83+ Lamp Replacement: 步骤 4 中的图像 1,2 Epson PowerLite 83+ Lamp Replacement: 步骤 4 中的图像 2,2
    • Loosen the two captive Phillips #2 screws securing the lamp.
    • Captive screws cannot be removed. They are secured to the lamp itself with retaining rings and will be removed along with the lamp.
  5. Epson PowerLite 83+ Lamp Replacement: 步骤 5 中的图像 1,3 Epson PowerLite 83+ Lamp Replacement: 步骤 5 中的图像 2,3 Epson PowerLite 83+ Lamp Replacement: 步骤 5 中的图像 3,3
    • Gently grip the lamp by the finger hold.
    • Remove the lamp by pulling it off the guide rail, straight out of the projector.
结论
2等其他人完成本指南。
Billy Fox
于02/22/22注册
467 声望
创作了3篇指南
团队
Clemson, Team 2-4, Hunter Spring 2022 Clemson, Team 2-4, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S2G4
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 807
