跳转到主内容
Epson PowerLite 822 Plus Projector Lens Replacement
你所需要的
  1. Epson PowerLite 822 Plus Projector Lens Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Flip the projector over.
    • Remove all 8 screws on the bottom of the projector.
  2. Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 2 中的图像 1,2 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 2 中的图像 2,2
    • Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
  3. Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 3 中的图像 1,2 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 3 中的图像 2,2
    • Use the spudger to disconnect it from the motherboard.
  4. Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 4 中的图像 1,2 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 4 中的图像 2,2
    • Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
    • Now completely take off the top of the projector.
  5. Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 5 中的图像 1,2 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 5 中的图像 2,2
    • Remove the 3 screws that secure the motherboard in place.
  6. Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 6 中的图像 1,3 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 6 中的图像 2,3 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 6 中的图像 3,3
    • Gently move back and forth the 11 JST connectors until they come out.
  7. Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 7 中的图像 1,2 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 7 中的图像 2,2
    • With the spudger lift the red plastic tabs from their connectors.
  8. Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 8 中的图像 1,3 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 8 中的图像 2,3 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 8 中的图像 3,3
    • Lift the motherboard and disconnect the JST connector underneath.
  9. Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 9 中的图像 1,1
    • Now, the motherboard is completely removed from the projector and you are ready to replace it.
  10. Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: 步骤 10 中的图像 1,3 Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: 步骤 10 中的图像 2,3 Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: 步骤 10 中的图像 3,3
    • Use a Phillips #2 screwdriver to remove the four 6 mm screws that hold together the fan bracket.
  11. Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 11 中的图像 1,2 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 11 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the four 6 mm screws that secure the projector.
  12. Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 12 中的图像 1,2 Epson PowerLite 822 Plus Projector Lens Replacement: 步骤 12 中的图像 2,2
    • Pull out the loose projector and it is ready to be replaced.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 166
